axle bearings
My non-clip was $35 (per axle shaft ) at most machine shops to remove to old and press on the new.
The inner seal can be tricky. Nothing special other than a good seal puller.
C-Clip and 8.25 is slide hammer to pop out the outer bearing and the outer seal out.
