86manche207 Posted September 26, 2015 Share Posted September 26, 2015 https://maine.craigslist.org/pts/5220981016.html does anyone know if i could make a set out of any of these axles and keep my np207 t-case my tranny and 2.8 motor? any help would be awesome thanks Link to comment Share on other sites More sharing options...
Pete M Posted September 26, 2015 Share Posted September 26, 2015 axle choice and engine choice are completely separate things. one rarely affects the other. :thumbsup: (unless you get a big v8 and puny axles, then one will affect the other :D ) early bronce axles suck unless you throw a lot of money at them. if I remember right, they have small ujoints, the front is low pinion, and the rear has little shafts and bearings. you'd be ahead of the game with late model XJ dana 30/8.25. or are you referring to the kingpin dana 60? that guy have a lot of stuff for sale. Link to comment Share on other sites More sharing options...
86manche207 Posted September 26, 2015 Author Share Posted September 26, 2015 axle choice and engine choice are completely separate things. one rarely affects the other. :thumbsup: (unless you get a big v8 and puny axles, then one will affect the other :D ) early bronce axles suck unless you throw a lot of money at them. if I remember right, they have small ujoints, the front is low pinion, and the rear has little shafts and bearings. you'd be ahead of the game with late model XJ dana 30/8.25. or are you referring to the kingpin dana 60? that guy have a lot of stuff for sale. those ones are a little out of my price range I'm just trying to figure out my options and wait for the right stuff for the right price Link to comment Share on other sites More sharing options...
Pete M Posted September 26, 2015 Share Posted September 26, 2015 what are the future plans for your truck? Link to comment Share on other sites More sharing options...
86manche207 Posted September 27, 2015 Author Share Posted September 27, 2015 what are the future plans for your truck? small lift 3 inches. rustys front flat fenders http://www.rustysoffroad.com/jeep-exterior-parts-accessories/jeep-body-panels-fender-flares-tire-covers/xj-cherokee/rustys-steel-fender-flares-xj.html and trim the back ones and run 33 10.5s and get front and rear bumpers. and fix body damage one side is pretty beat. mainly just the passenger door. Link to comment Share on other sites More sharing options...
Crash Posted September 27, 2015 Share Posted September 27, 2015 For the rear, a D44, C8.25, F8.8 would work for your needs. For the front, Truss/sleeves, chromo's, full case locker for the 30 4.56 gears front and rear. Link to comment Share on other sites More sharing options...
86manche207 Posted September 29, 2015 Author Share Posted September 29, 2015 For the rear, a D44, C8.25, F8.8 would work for your needs. For the front, Truss/sleeves, chromo's, full case locker for the 30 4.56 gears front and rear. Thanks for the advice I think that's what I am going to go for I keep an eye of CL everyday. Shouldn't be hard to find one and my brother has a 2wd ranger on the way out and it might have a 8.8 :-) Link to comment Share on other sites More sharing options...
Pete M Posted September 29, 2015 Share Posted September 29, 2015 likely it will not. if I remember right, the 8.8 was pretty rare under a ranger, where as every Explorer 96-01 will have an 8.8 and disk brakes. and 4.10 gears are pretty common. try car-part.com for a junkyard search. don't forget that v6 and v8 models have identical axles, just the outside bracketry changed (which you're going to cut off anyways) so be sure to search for both. Link to comment Share on other sites More sharing options...
86manche207 Posted September 29, 2015 Author Share Posted September 29, 2015 likely it will not. if I remember right, the 8.8 was pretty rare under a ranger, where as every Explorer 96-01 will have an 8.8 and disk brakes. and 4.10 gears are pretty common. try car-part.com for a junkyard search. don't forget that v6 and v8 models have identical axles, just the outside bracketry changed (which you're going to cut off anyways) so be sure to search for both. thank you very much never knew about car-part.com there a good amount near me. Link to comment Share on other sites More sharing options...
