dancome433 Posted September 13, 2015 Share Posted September 13, 2015 I know this for an XJ not an MJ, but I'm sure there plenty of people here have or had XJs or have seen them in junkyards. As the title states I need a window regulator from a 2 door 97+ XJ with power windows, thanks in advance. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 14, 2015 Share Posted September 14, 2015 What side ? Link to comment Share on other sites More sharing options...
shelbyluvv Posted September 14, 2015 Share Posted September 14, 2015 Regulator or Master Power Switch? Link to comment Share on other sites More sharing options...
Project5337 Posted September 14, 2015 Share Posted September 14, 2015 http://www.steigerperformance.com/ Getting impossible to find two door regulators. I have used this kit to fix a few and it works great. Link to comment Share on other sites More sharing options...
dancome433 Posted September 14, 2015 Author Share Posted September 14, 2015 Sorry that would probably help, I need the driverside regulator. Master switch is good; the motor wasn't getting power and I'm sure the previous owner cut the cable from the regulator to be able to lower the window. I fixed the motor, turned out to just be the wire connector to the motor, now the motor works fine, checked the master switch and it works fine as well. I've actually been looking at steigerperformance's pictures to get an idea how the regulator works(being mine wasn in pieces inside the door) and while the fix kit they offer would help fix my regulator it won't fix it completely unfortunately, Link to comment Share on other sites More sharing options...
