512tr Posted February 15, 2006 Share Posted February 15, 2006 The alternator stopped charging last week-end, I'm able to get a new XJ alternator. Will a 4.0l XJ (88-90 mod) 100A alternator fit my 87 MJ ? I assume both have built-in voltage regulator? Link to comment Share on other sites More sharing options...
87manche Posted February 15, 2006 Share Posted February 15, 2006 should. The engine compartment is pretty much the same between xj and MJ. Link to comment Share on other sites More sharing options...
square Posted February 15, 2006 Share Posted February 15, 2006 Yes It should fit All the 4.0L are the same in the range 87-90 Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted February 15, 2006 Share Posted February 15, 2006 YUP!! I have one for mine sittin' in the garage. Just waitin' for warmer weather to drop it in!! Good luck!! CW Link to comment Share on other sites More sharing options...
Pete M Posted February 15, 2006 Share Posted February 15, 2006 Oooo, not so fast there guys. While the XJ and MJ are essentially the same up there, Jeep used a few different alternators up front, even in the same model year. Only way to know for sure is to check. When I ordered my 170A for my 88, I had to choose between 3 different mounting styles to figure out which would fit in my truck. (If I remember right, mine takes the GM style) Jeep on! --Pete Link to comment Share on other sites More sharing options...
whowey Posted February 16, 2006 Share Posted February 16, 2006 All the 4.0L are the same in the range 87-90 That's not completely true. In 87, there were some differences. Different mountings for some of the accesory brackets, there are different part numbers for some parts. Variances in vacuum line routings and the like. Remember 87 was the last year of AMC's independence, and the first year of completely new drivetrains in the MJ/XJ. Lots of funky stuff happens, even more than was the 'norm' at AMC. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted February 16, 2006 Share Posted February 16, 2006 Well, I'll be!! You learn something new everyday!!! I have four here to look at. My buddies, '88, my two '89's (1 XJ & 1 MJ) and a '90 XJ. They are all the same size shape and mounting. I based my answer on those. Sorry for the miss-information!! CW Link to comment Share on other sites More sharing options...
512tr Posted February 17, 2006 Author Share Posted February 17, 2006 Thank for the replies, the alternator is ordered...(should fit XJ 88-90), so I just have to wait and see if it will fit in the existing bracket. Link to comment Share on other sites More sharing options...
