Defroster vent only blowing/ AC converting/recharging question
I have a feeling this should be a easy fix but I really have no idea. lol
 The defroster, windsheild vent, is only blowing. The upper and lower vents have no air flow. All different fan speeds work..
Anyone have an idea?
Also I have, new in packaging, AC lines. I would like to install these and have AC. WOuld I just install the new lines after vecuuming out whats left in the old system, and just recharge it again? or do I have to convert something?
Follow the hard plastic vacuum line that runs forward along the right side inner fender and terminates at the vacuum canister behind the front bumper. The plastic line usually breaks where it passes through the forward bulkhead in front of the battery.
