Dis Posted August 10, 2015 Posted August 10, 2015 I have a 1990 chief , i am trying to add an Overhead console from a 1990 xj i have the console and the mounting brackets and the wiring from the donor vehicle , my problem is the wiring, I have not been able to find a write up for this, involving an MJ. have no problem having to modify the harness, and electrical work does not scare me. It does appear i do have the ambient sensor temp in the middle of my bumper. i would like ambient temp to work, as i do live in Texas. if someone could post a link or so or even pictures on how they did i would be very grateful.
HOrnbrod Posted August 10, 2015 Posted August 10, 2015 MJ's never had overhead consoles from the factory, so you will have to use a wiring diagram for a 90 XJ. Does your console have keyless entry?
Dis Posted August 10, 2015 Author Posted August 10, 2015 MJ's never had overhead consoles from the factory, so you will have to use a wiring diagram for a 90 XJ. Does your console have keyless entry? No it doesnt, i don't plan on adding it, may add it in the future, but if i do i will use an aftermarket alarm to unlock the doors.
HOrnbrod Posted August 10, 2015 Posted August 10, 2015 This might help: http://comancheclub.com/topic/36266-xj-overhead-console-temperature-sensor/?hl=overhead+console
Dis Posted August 14, 2015 Author Posted August 14, 2015 Sorry, Pioneer , I mean, was taking apart the trim/door panels to wire in new speakers. And on the trim it said cheif, and it was about midnight when I posted that. So I wasn't firing on all cylinders. But I did look at the link hornbrod linked. I wasnt able to get an of the links to work.
