putting 1990 auto Cherokee in 1986 manual Comanche/ seeking any insight
It change alot from the 1986 to an 1987 and on comanches, In order for you to make the engine swap, you need to "massage" the firewall, and the radiator brackets needs to change. And theres some more think you got to change, including motor mounts if I can recall correctly.
Theres some post in the DIY section about this, check em out.
