1988 MJ Longbed - $5200 - Former MJOTM in michigan
Blue XJ
This is your chance to own a piece of history, The April 2014 Comanche of the month is up for sale! Get it now before it's too late!
I've had less and less time to enjoy my Jeep, so I think the time has come to let someone else enjoy it.
  • 4.7l Stroker with ~20k miles (1995 Block, 7120 Head, 12 CW crank, 24lb injectors, Hesco FPR)
  • AX15 Manual Transmission with External Slave
  • NP231 Transfer Case with AA SYE installed, ~20k miles on complete rebuild
  • 6.5” Rock Krawler Coil Springs, RK 3 Link Long Arms, RK Track Bar, Alcan 6” Leaf Springs (SUA), Antirock Sway Bar
  • Dana 30 with 4.56 Yukon Gears, ARB Air Locker, Warn Chromolly Inner and Outer Shafts, Warn 5x4.5 Manual Hub Conversion Kit, 1-Ton Over The Knuckle Steering, Bilstein 5150 Shocks
  • Chrysler 8.25 Rear Axle with 4.56 Yukon Gears, ARB Air Locker, 29 Spline Yukon Alloy Shafts, ZJ Disk Brakes, Bilstein 5125 Shocks
  • Dynotech front and rear driveshafts
  • 35” BFG Mud Terrain KM2’s (99% Tread) on 15x8 American Racing wheels
  • Custom Bumpers with Warn XD9000i winch
  • D&C Extreme XJ Cage Modified to Fit with Custom Roll Bar in Bed
  • On Board Air w/ Air Chucks in Front Bumper and Bed
  • JCR Sliders
  • Steel Tube Flares
  • 97+ XJ Front Sheet metal
  • 97+ XJ Doors with Power Windows
  • Cobra CB w/ Firestik Antenna
  • Rough Country 4” LED Off Road Lights
The cab corners are starting to rust, the drivers side is still solid, but the passenger side made it all the way through. The paint has seen better days, I used implement paint, it has held up great to trees and rocks, but it is faded, and starting to chip in a few areas that I used body filler.
I'll post more pictures tonight, my work blocks photo sites so I can't do it from here.
Image Not Found
 Image Not Found
Image Not Found
Here is the MJOTM thread, which also includes the build thread at the bottom.
http://comancheclub.com/page/articles.html/_/news/mjotm-april-2014-blue-xjs-88-lon-r33
$6,000 firm
$5,200
Apologies if off topic, how much did you pay for your set of Alcan leafs? Mil-wrapped?
Looks like a nice truck. Personally not a huge fan of green, but with our tractor motor, I guess it fits well.
GLWS
I bought them from someone on here a long time ago, he bought them from Alcan and never used them, I think I paid $350 shipped for them.  I'd have to double check, but I do not believe they are mil-wrapped.
I'm not a huge fan of the green either, but it was cheap and holds up to trees very good, so it works for me.
  • 4 months later...
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
Archived
