dustyinthedirt Posted June 12, 2015 Posted June 12, 2015 so the time has come to replace my fuse box. when i bought my truck the P.O. said the clutch reservoir was leaking. when i inspected it of course it was leaking down on the fuse box. no clue how long this had been going on. also the P.O. had put bigger watt fuses in most of the fuse box. now i have to check to be sure my brake lights are actually working every so often because there will be residue on the fuse and won't let it make a good connection. just the other day the turn signals quit working checked the fuse and the metal connectors the fuse sits against two of them where missing. along with a few other fuse slots melted. what i am looking for is somebody to tell me if i can use a fuse box out of a Cherokee? i know that from the doors forward they are the same but i wasnt sure about the fuse box. Also how much of a pain in the rear is this going to be to change?
Megadan Posted June 12, 2015 Posted June 12, 2015 I believe Hornbrod is referring to this thread, which is very recent. Fuse box and wiring have been beaten to death lately, a cursory glance through this section should prove helpful.http://comancheclub.com/topic/47319-fixing-fuse-block/
