External slave cylinders
What's up fellas
So I'm close to halfway through my ax15 swap and I had gotten 2 used clutch master cylinder and clutch slave cylinder kits from the jy and followed "factory" procedures to bleed them....
But when I go to install everything in place the rod pops off when I press the peddle and falls into the bell housing
Is it easier to just buy a whole new pre-bled set or
Is there anyway to prevent this....?
Well the 2 that I have are used from a jy till I can afford a new set up...the zip tie was already popped when installed...
It would be installed correctly until I check for peddle pressure after a few pumps it would pop out of the cylinder and drop all of the clutch fluid
