neohic Posted May 20, 2015 Share Posted May 20, 2015 There's enough '97+ swaps around to ask here, I think... The horn in my '98 XJ does not work. Right now there's no horn physically in it, but I don't get power out to the wires on either side where they should be. When I push the horn button, I hear a clicking over in the passenger side footwell (I assume there's a relay for it) but I doubt that it clicks loud enough for outside traffic to hear to be a suitable substitute. Anywhere else I can look for a fuse or...? If it matters at all, the turn signal doesn't shut off by itself when you complete a turn nor do the high beams work without holding the switch. Thanks dudes! Picture... because people like pictures. Link to comment Share on other sites More sharing options...
Eagle Posted May 20, 2015 Share Posted May 20, 2015 Yes, the click is the relay. So your horn button works and activates the relay. The problem is somewhere between the relay and the horns. Link to comment Share on other sites More sharing options...
neohic Posted May 21, 2015 Author Share Posted May 21, 2015 I figured as much. I guess I was hoping someone who's done a '97+ swap on their MJ would chime in with something along the lines of, "Oh yeah! Check on the connector under the left muffler flap that's labeled 'HAS NOTHING TO DO WITH THE HORN' because it actually has everything to do with the horn." :D A guy can hope for something as simple as that anyhow, eh? Link to comment Share on other sites More sharing options...
shelbyluvv Posted May 21, 2015 Share Posted May 21, 2015 Behind the glove box door is a bundle of wires. Mine were cut by the door opening and closing. I lost all power to the passenger side door and horn. Weird but I repaired them and everything works now. Link to comment Share on other sites More sharing options...
Eagle Posted May 21, 2015 Share Posted May 21, 2015 If I get back from class early enough this evening I'll see if I can find the horm circuit in the 2000 XJ FSM. No promises, though -- the electrical diagrams in that book run over 100 pages. :Yike!: Link to comment Share on other sites More sharing options...
