88 renix 4.0 timing help!!!!!!!!!!!
The Renix distributor is not adjustable, and has no vacuum advance, so both of those are a no-go.
I don't think you'll find anything out there that can interface with the Renix ECM, either.
I need help to connect a timing retard box like msd or figure put a way to retard the timing on my engine for nitrous
I had something like that on a Miata with a supercharger. Triggered by knock sensor and retarded the timing via the CPS circuit.
