CJ's MJ Posted April 20, 2015 Author Share Posted April 20, 2015 You can start by swapping in Jeep ZJ V8 front end parts. Tie rod, drag link, sway bar, and track bar are all beefier and bolt right in with no modifications. The 93-98 ZJ steering gear boxes are a quicker ratio and are also bolt-in. Any particular years I'm looking for tie rod, drag link, sway bar, and track bar? Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 20, 2015 Share Posted April 20, 2015 93-98 Grand Cherokees. Link to comment Share on other sites More sharing options...
CJ's MJ Posted April 20, 2015 Author Share Posted April 20, 2015 Okay thanks will order the parts today. Hopefully have them in 2 weeks. With track bar should I buy an adjustable one because of the lift? Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 20, 2015 Share Posted April 20, 2015 How much lift? Is your axle centered now? Link to comment Share on other sites More sharing options...
CJ's MJ Posted April 20, 2015 Author Share Posted April 20, 2015 I believe it's a 4.5" lift. As far as being centered not sure. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 20, 2015 Share Posted April 20, 2015 Check your lift like this:Â http://comancheclub.com/topic/11098-how-to-measure-ride-hight/ Link to comment Share on other sites More sharing options...
CJ's MJ Posted April 20, 2015 Author Share Posted April 20, 2015 Okay will do as soon as it stops raining. Link to comment Share on other sites More sharing options...
Incommando Posted April 20, 2015 Share Posted April 20, 2015 Many things can cause a pop when turning. A common cause is that the body side mounting hole for the track bar has been wobbled out. Link to comment Share on other sites More sharing options...
CJ's MJ Posted April 20, 2015 Author Share Posted April 20, 2015 Check your lift like this: http://comancheclub.com/topic/11098-how-to-measure-ride-hight/ Just measured the top of axle to frame approximately 12.5" on front. So using the diagram and subtracting the standard height should have 4.5" lift. Back is a spring over axle. Not sure how to take that measurement. Would it be better to get the adjustable track bar? Link to comment Share on other sites More sharing options...
Rockfrog Posted April 23, 2015 Share Posted April 23, 2015 Given that the steering damper is mounted through the passenger side sway bar mount ... If those bushings are worn, it will make a pop when you turn. They probably don't fit properly either, mount stud for the sway bar had 1/2" ish hole, damper studs are about 3/8" with around a 3/4-7/8" bushing hole. Link to comment Share on other sites More sharing options...
CJ's MJ Posted April 23, 2015 Author Share Posted April 23, 2015 Given that the steering damper is mounted through the passenger side sway bar mount ... If those bushings are worn, it will make a pop when you turn. They probably don't fit properly either, mount stud for the sway bar had 1/2" ish hole, damper studs are about 3/8" with around a 3/4-7/8" bushing hole. I am replacing the damper to the correct one. I already have it ordered just waiting on it to arrive. Sure wish I would have found you guys before I replaced it. Hate throwing money away, but I would much rather have it fixed the right way. Thanks for all the advice and help. Link to comment Share on other sites More sharing options...
