Fernando87mj Posted April 4, 2015 Share Posted April 4, 2015 Does anyone know if the 97 + xj window seals fit without modification ? I scored some in good condition at jy today and can't seem to get them to go in Here's a pic of what I mean Link to comment Share on other sites More sharing options...
Crash Posted April 5, 2015 Share Posted April 5, 2015 They will not work. The only door items I know swap late model to early model is the mirrors and the door seals between the cab and the doors. Maybe the late model stock tweeters (other that wiring/crossover). Link to comment Share on other sites More sharing options...
buckwheat Posted April 5, 2015 Share Posted April 5, 2015 Check out BleepinJeep on youtube. Matt (the guy that does the vids) made a how to on swapping those pieces. It is not plug and play, you have to modify the new pieces. Ill see if I can find the exact video. Link to comment Share on other sites More sharing options...
Co-MAAAN-cheee Posted April 5, 2015 Share Posted April 5, 2015 I put trim from a 2000 on mine. It requires some cutting. I had to peel away all the rubber from the back of the trim where it installs over the wing window. Then I ground off a lip of metal so the back was flat. Link to comment Share on other sites More sharing options...
88whitemanche Posted April 8, 2015 Share Posted April 8, 2015 Link to comment Share on other sites More sharing options...
