slop-over/spit back when fueling
Is fuel actually spitting out while you are trying to fill up or are you talking about not being able to tell when the tank is full and having overflow problems?
If it is the first one, i would bet the fill hose is kinked or the breather hose is kinked/clogged.
If it is the second, you will just have to listen more closely like reubj said. Thats about all you can do.
