Electrical Connectors, under dash
I need some help identifying some connectors under the dash.
Its a transplanted harness from a 1991 XJ into an 87 MJ.
Black connector, 4 pin (heavy gauge wire)
yellow plug, coming from steering column.
White 2 pin connector (Wh/Bk goes to fuse panel, Wh/Pk goes to break switch, va an adapter)
Black connector, 4 hole, with 3 wires
Blue connector (fits the break switch too, but is not connected)
And if anyone knows, what is the "red" relay?
Thanks!
Ok, let me have a quick go at this ...
Mid right of picture, black connector, 4 wires - receptacle for headlight delay timer.
Translucent connector upper right - emissions timer.
Yellow plug with circuit board type connector - cruise control.
White 2 pin between fuse panel and break switch - again for cruise control (shuts off cruise when you tap breaks).
The rest I don't know off hand, need to sit in front (under my dash and it's a 3hr boat ride, and a 4hr crew bus ride away).
Awesome, thanks for your info. I suppose I can remove the cruse control wires, Not going to have it.  I wonder if the blue connector is related to cruse control..? I was thinking its for tow package though. That blue connector fits the break switch too, same pin and size.
I need to do some research on the head light dimmer. I'm assuming it leaves the head lights on for a set time after key off?
  On 3/25/2015 at 2:57 AM, schardein said:
The red relay is for the rear window defrost in rear hatch of XJ.  Works like a regular relay but goes off after set time.  Replacement parts stores list them for $$$$$ but they never seem to go bad.
That's good to know. I'll save that relay, may find a use for it in the future. Like electric fan delay, or light delay.
