88 4.0 5speed randomly dies
Well I've had the new truck for about 2 week now and the last couple days I've been driving it, it will randomly dies. Usually when I have my foot on the brake. It stats back up every time but it's starting to do this more often, it has don't when the truck is warm and cold. I've never had this issue before with my other 88 4.0 and I'm not sure where to even begin to look. It also will idle extremely high sometimes when I start it back up. Any help would be greatly appreciated.
The problem you are experiencing is identical to mine in almost every way. My problem turned out to be a failing TPS sensor, but before you go replacing anything do this.
The next time you start your truck and it is idling normally, (850 rpm or so) pop the hood and disconnect the IAC valve. Then drive the truck like that for a day or so. If the stalling/high idle after restart goes away replace the TPS.
I would also take the time to thoroughly clean the IAC and throttle body.
