Converting from auto to 5 speed and would like to find harness for tranny and transfer or how to make auto harness work
Oh , ok . I'm planing on doing the opposite but shipping would be problem . I've got a 89 with the ba 10 and 4.0 .which wouldn't work anyhow . I believe someone on here has done that using the auto harness , but I don't remember who .
  You can probably make the existing harness work.  There really isn't much wiring on the HO 4WD AX-15.  VSS is probably the same connector (2 wire I'm assuming), back up light switch is 2 wires, and the dash light is controlled by the switch in the T-case. Is your rig already 4WD?  If so then the back up light switch will be the only thing to figure out.
