What is the best website for Comanche parts
The vast majority of the parts are shared with the same year XJ Cherokee most of those parts are plentiful and available from dozens of sources.
Some parts are MJ-/specific and are only available used from other MJ's or from a handful of specialty shops.
Was there something in particular you were looking for?
Where you get parts depends on what you're looking for. As Incommando said, lots of parts interchange with the XJ Cherokee; everything from the doors forward is identical to a four-door XJ of the same year.
Door panels or the whole door. As long as it's four door.
Yep. the front doors off of a four door work. Remember than sometimes year changes and trim levels effect door panel appearance so if you buy a pair they may not exactly match your particular originals
The mirrors off an XJ will fit. If you're looking for floor mats, the MJ's floor pan is a little different from an XJ's but word is the preformed XJ ones fit well enough. Stockinteriors.com has replacement molded carpets, but I don't know about their fit.
