Voden038 Posted February 24, 2015 Posted February 24, 2015 Hello!! I am a new Comanche owner. My grandfather left a 1990 to me when he passed away. I have enjoyed the truck for quite a while now.. but I am now in a pickle! My clutch wasn't engadging when I depressed the pedal. Grinds horribly when trying to get it into reverse, and I have to force all gears into place! Took it to the dealership... told them the slave must be out.. what can ya'll do.. and of course they replaced EVERYTHING. After a full clutch kit, slave and master replacement, the clutch pedal still remains not more then a few inches off the floor board. The dealership tells me that the part required to fix the pedal assembly and the ENTIRE clutch assembly is no longer avalible. My question is, which Jeep model will fit the Comanche clutch and/or clutch brake assembly, and what alterations must be done to fit it? I am done jerking off the dealership. Thanks!!!
yxmj Posted February 24, 2015 Posted February 24, 2015 They are pulling your wire first you need to see if you have an internal or external slave then we can advise from there.....no offence but do you know the difference.
87MJTIM Posted February 24, 2015 Posted February 24, 2015 Can you give us more detail about your MJ? Is it 4cyl or 6cyl? 4 spd or 5 spd? As for pedal assemblies, the brake and clutch pedal from a similar era XJ will fit. From you description, it sounds like the system needs bleeding. BTW - Welcome to the addiction! :waving:
