Jeepjeff859 Posted February 5, 2015 Share Posted February 5, 2015 A while back i replaced the clutch disc, pressure plate, release bearing. clutch slave, and clutch master after i replaced the clutch master i noticed the clutch pedal now sits about 1 in. past the brake pedal like it as a shorter push rod. i have been having a problem getting a good clutch pedal. Could the shorter push rod not be giving me enough travel? could someone give me length of theirs so i can measure mine or maybe a part number ? Link to comment Share on other sites More sharing options...
Eagle Posted February 5, 2015 Share Posted February 5, 2015 Did you replace your push rod? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted February 5, 2015 Share Posted February 5, 2015 There is supposed to be a plastic cone pushed onto the end of the push rod that rides in the throw out arm. This increases the length of the rod by almost an inch. I ran into the same issue when I did mine. It just wasn't getting enough throw to fully disengage. Then I looked at the pushrods and transfered the plastic cone and all was good. You would think it would come with a new one on the slave cylinder but it doesn't. Hope this helps. Link to comment Share on other sites More sharing options...
Eagle Posted February 5, 2015 Share Posted February 5, 2015 Okay, now I have another question: Which push rod? I was thinking the push rod from the peddle to the master -- I'm accustomed to the BA10/5 with the internal slave, so I forgot that a clutch with an external slave also has a push rod on the lower end. Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted February 5, 2015 Author Share Posted February 5, 2015 I'm talking about the push rod on the master cylinder that connects to the pedal Link to comment Share on other sites More sharing options...
yxmj Posted February 5, 2015 Share Posted February 5, 2015 Do you still have the old master ? Pull the rod out max and measure the rod from the lip of the cylinder to the center of the hole....do the same on your new one. I have changed and rebuilt masters but newer come across a rod that was a noticeable 1" different. Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted February 5, 2015 Author Share Posted February 5, 2015 I don't have the old one it was bent, but the pedal sits about a in past the brake pedal and with the old one it didn't Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted February 5, 2015 Author Share Posted February 5, 2015 The clutch isn't disengaging fully so maybe the slave push rod is a bit shorter Link to comment Share on other sites More sharing options...
yxmj Posted February 5, 2015 Share Posted February 5, 2015 What is the measurement from the lip of the master to the center of the hole were the pin for the pedal goes? Link to comment Share on other sites More sharing options...
yxmj Posted February 5, 2015 Share Posted February 5, 2015 ???? Now you are talking about a different Rod????? :hmm: Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted February 5, 2015 Author Share Posted February 5, 2015 The push rod on the master is about 4 in, I don't have a ruler around at the moment, and I'm starting to think that since I don't have that plastic cone on the slave that I'm losing the little bit of length needed to release the clutch Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted February 5, 2015 Author Share Posted February 5, 2015 And the bolt holes on your master are vertical Mine are horizontal Link to comment Share on other sites More sharing options...
