Old man with MJ Posted January 26, 2015 Share Posted January 26, 2015 Told It has a groove in crankshaft; read somewhere about a double lip seal (maybe Mopar) and or a stainless steel crankshaft sleeve? Has anyone used either of these to fix a leaking rear main seal? This is an 88 4.oL Thanks Link to comment Share on other sites More sharing options...
ScottJeep Posted January 27, 2015 Share Posted January 27, 2015 The grooving sounds like an issue that is usually experienced on the FRONT of the motor caused by the seal on the front cover. Have never had to use the kit, some of which include the sleeve. Link to comment Share on other sites More sharing options...
nitroxsteve Posted January 27, 2015 Share Posted January 27, 2015 Did the person who told you this actually see the groove or are they making a prediction? Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 27, 2015 Share Posted January 27, 2015 http://www.silver-seal.com/category/shop.engine_parts.repair_sleeves/ Link to comment Share on other sites More sharing options...
Eagle Posted January 27, 2015 Share Posted January 27, 2015 I never heard of a sleeve for the rear main seal. I'd say it's impossible -- how could you installit, even if you took the crank out of the block? I believe the double-lip seal is a Felpro product, and available from NAPA. Link to comment Share on other sites More sharing options...
Old man with MJ Posted January 27, 2015 Author Share Posted January 27, 2015 Mechanic was replacing slave,had the transmission out, I may have asked him to look at leak in back of engine while he had it apart. He doesn't seem to be thorough in his work, this year I noticed some lines missing on the passenger side of the bellhousing,may be for vacuum lines axle disconnect doesn't work. Thanks for the replies, first I need to replace the valve cover gasket and clean the engine then I can tell where oil is leaking,only that can wait until spring! The double-lip seal will probaly work for me,getting the oil pan off would be my first problem! Link to comment Share on other sites More sharing options...
