bumpy Posted May 23, 2007 Share Posted May 23, 2007 so i went boggin in a corn field then 3 days later stopped to get gas, turned it back on and it backfires, doesnt idle and shakes alot, when i give it gas it gasps for air and when i let off the gas it backfires and dies.... ideas? ive searched but I'm retarded when it comes to that stuff. 88 4.0 253k... I'm guessing idle air controller or tps? not too literate when it comes to engines. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 23, 2007 Share Posted May 23, 2007 check your AIR FILTER first. then pressure wash the engine bay (careful on sensors) and look it over Link to comment Share on other sites More sharing options...
Mitch Posted May 23, 2007 Share Posted May 23, 2007 did you get some bad gas? try adding some dry gas or something like that. Link to comment Share on other sites More sharing options...
Pete M Posted May 23, 2007 Share Posted May 23, 2007 I would hesitate before pressure washing the engine bay. There are a LOT of things in there that do not like to get wet and even more things that don't like the force of the watter hitting them. Plenty of people have caused headaches by spraying the wrong thing (me included). Link to comment Share on other sites More sharing options...
Wildman Posted May 23, 2007 Share Posted May 23, 2007 I'd hate to say it, but with 253K on the engine........I would check out the timing chain. Timing chains jump a tooth when there getting ready to go, when you shut the engine off, that's when they jump. The stoping of the engine "snaps" the chain. With the back firing and trying to suck air, and no power, it would be a good idea to check it out. Any timing chain I lost was from turning off the engine, and then re-start caused the same problems your having. Link to comment Share on other sites More sharing options...
