agamble Posted January 11, 2015 Share Posted January 11, 2015 I am getting ready to replace the cracked exhaust manifold and gasket on my comanche; it's an 89. I figure while I am in there, I might as well replace the manifold bolts. I have been doing some web surfing and come up empty handed on the creect bolt sizes and lengths I would need. I have found several posts with bolts sizes and lengths for the 91 and newer cherokees. Would ours be the same as the 91 and newer or something different. Thanks for the help. Link to comment Share on other sites More sharing options...
cz777 Posted January 12, 2015 Share Posted January 12, 2015 i am dumping all the bolts to studs[grade 8] high heat steel with brass nuts with holding washers ........other thing is the use of copper rtv very thin on the gasket ..... Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 12, 2015 Share Posted January 12, 2015 3/8 x 1 1/4" Studs are not necessary and you can get grade 8 at TSC by the pound.....cost you about $2.50 Grade 5 is fine too. Link to comment Share on other sites More sharing options...
