My brother swapped his dummy light dash cluster for a full guage cluster,His oil pressure and water temp. guage won't work .I'm telling him different sensors for guages vrs. lights.If so does anyone have any part numbers.XJ  is a 94 model. Thanks
Just about every parts store I've been to, asks me "lights or gauges" when I ask for the two SENDERS. Emphasize SENDERS.
If they don't know the difference between a sender and a sensor, go to another parts store.
Remember the sender for the temp gauge is a one wire connector at the drivers side rear of head (so no Teflon tape or thread sealer)...the oil pressure sender mounts per usual for a 94...just has different guts.
Like Paradise said... it is a small unit at the rear of the head for twmp. The parts monkeys will try to sell you the one by the thermostat and that is not the one that needs to be changed.
Reviving this so I don't have to stsart a new post.
My truck is a '88 Pioneer/Comanche with a 4-FOUR cyl. I just spent about 5hrs digging around at a yard that i knew had some older Jeeps. Found one that had the same speedo connection and did the happy dance.!!
Got home and sstarted pulling my dash all apart (finding all sorts of crap from 230K+ miles)
Cleaned as much as I could on the 'new' cluster to go in and was all excited. Even found a original clock to go in along side. Got it all back in, along with the sending units for them..........
NO TACH or OIL PRES or FUEL and Volts goes to 9..  Very disappointed to say the least. Especially the tach.  If you don't know me.. "I HATE WIRING" and this just re-enforces this feeling.
Most every thread that I've read (even on other sites states it's plug and play) Of course, I know they're used sending units. They will get changed out this next week.
Just don't know where to start 'checking'. Cluster or sending units.
REMEMBER.. It's a 4cyl if that matters.
PeeJ    Did you guys ever figure this out?
What happened?
Errol
