JeepsOLot Posted January 5, 2015 Share Posted January 5, 2015 Year, Make, Model. 1986 Jeep Comanche Base(?) Long Bed 2WDImage, Image Not Found Image Not Found Image Not FoundImage Not Found Engine / Trans / Transfercase / Front axle / Rear axle / WheelbaseOriginal: 2.8L V6/ TF 904 Auto/ 2WD/ D44/ Long Bed Build date: The sticker is totally wiped out, have no clue.Current Location: Stuart, FLStatus: Cleaning up, and getting the drivetrain together, bought Jeep without motor or trans.Notes: Had a column shift. I'm thinking this is a late '86, as the firewall has the indentation for the 4.0, and it has the D44 instead of the AMC 20 or D35. Has a drop-in bedliner, bench seat, brown interior, base gauge cluster with idiot lights. It will be getting a 4.0, AX15, and possibly a 242 with D30. Current owner: Me, Jerry Murphy Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 21, 2019 Share Posted May 21, 2019 Build date: 5/28/86 Link to comment Share on other sites More sharing options...
JMO413 Posted June 28, 2020 Share Posted June 28, 2020 TL62 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR DGZ Transmission- 4-Spd. Automatic,MT643 EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING Link to comment Share on other sites More sharing options...
