Bushwhackers V.S. Napier V2's
So I've put most projects on hold and decided I would start on some body work. Now that the work shops insulated i figured it'd be a good time. Well I've wanted to put on either Bushwhackers or Napier's once I'm done! I wanted to see pictures of your MJ's or XJ's with either or and why you like them or why they're better!
The BWs cover the fuel door on long beds and are thin brittle plastic. One smack on a tree will pull the bolts through the flare. You then have to epoxy them back together. I had them on my XJ and a Ranger. Doug's flares are just all around a better product.
  • 2 years later...
