Yet another no start. Renix 6 cyl
Things I have swapped
Cps
Fuel pumps+sending units
Fuel pump resistor
Spark plug wires
Coil
Ignition control unit
Facts
Tested good cps installed
,fuel delivery+fuel pressure good
12v to the ICU
No power on coil tower output - new coil installed + 2 other know. Good coils
Is there a way to test the cps harness to the ecu?
Or what else can I try?
Are you getting a good spark at the spark plugs? do you have compression? as far as testing the CPS signal to the ECM you will need a wiring diagram and back probe the " return" A/C signal from the CPS to the ECM at the ECM connection. Then you can see if you have a 4.5 to 5 volt reference to the CPS at the CPS connection ( sorry I don't have the wire color/locations for this) IIRC there was a campaign/recall that bypassed the fuel injection harness and connected the CPS directly to the ECM for a cleaner signal, I did this on my Comanche and it was very quick and easy,if you plan on doing this make sure you use a grommet to run the wires through the firewall and a good water proof connection.
