Pillar lights on at half brightness
So today, my MJ decides it needs more attention.
My Pillar lights are on all the time. Drivers door switch is not, passenger works fine. Headlight switch seems fine.
When I open the doors, the lights go full bright as would be expected.
I have Euramtec lights with LED bulbs in them.
Even with key off the Pillar lights are on at what I would say is a 50% bright level.
I hoping my drivers door switch is the issue, I had pulled it at one point cleaned and tested and had it working for a month. Then it just stopped, is it possible for it to leak voltage?
I'd vote its your door jamb switch since you say you cleaned and tested it recently.  Somehow its grounding or having a closed switch condition with your doors closed.
I've never had any luck making old door switches work by cleaning them, so I just replace them with new. I have experienced over tightening the nut on some can cause the switches to fault or stay closed, but I haven't had much experience with jeep door switches, if there's a difference at all.
So, got a new switch, seems to solve the issue but creates another.
The part store had a listing for a switch that will screw in but uses a three prong plug. So we ordered in a 1986 switch (BWD part number S750) which appeared to match mine. It came in and is ALMOST identical ... except the treaded fitting is too large. Looks to be 7/16" thread (maybe 1/4" npt) whereas the stock switch was 1/8" NPT (roughly 5/16" tapered thread)
Is the door jamb mounted into a threaded boss or is just a simple hole, drilled then tapped in the body metal. What I plan to do is drill the hole accordingly to fit the new switch....
Or does someone have a proper BWD or Dorman part number to use.
ok... So of course now the passenger side is acting up... Go figure.
Anyone have the passenger side part number handy... Against my better judgement I tried the parts store again... Same damn wrong switch, with the 3-prong plastic connector, dude looked at me like "that's the right part, your truck has the wrong one, my book says so" ... I just walked away, shaking my head in frustration.
Thanks
