Jeep Driver Posted November 25, 2014 Share Posted November 25, 2014 I'm getting ready to order my Harland Sharp roller rockers. 2.5 and 4.0 rockers are non-adjustable yet- * Harland Sharp original series, pedestal mount, Jeep 4.0L Inline 6, roller rockers are designed to be a replacement for the factory rocker that fits under the stock valve cover. Simply remove the factory rockers and rocker stands and replace with your new Harland Sharp roller rockers.* These non-adjustable rockers are designed to the factory specs. If you change camshafts or machine the heads, you will have to correct your pushrod length. Always check before installing.* We recommend always checking for head and valve cover clearance and proper lifter preload. Rocker mounts on head have not been machined, cam is one step above stock, push rods are stock. Anything I need to concern myself with here? Thanks Link to comment Share on other sites More sharing options...
Jeep Driver Posted November 25, 2014 Author Share Posted November 25, 2014 Alright........just realized it's the loss of height by a couple of thousandths for having the deck and head resurfaced....... Still, should I be concerned or is there enough tolerance in the lifter? Link to comment Share on other sites More sharing options...
benjy_26 Posted November 25, 2014 Share Posted November 25, 2014 How much did you deck your head? Link to comment Share on other sites More sharing options...
Jeep Driver Posted November 25, 2014 Author Share Posted November 25, 2014 I'll have to contact the machinist to find out. Link to comment Share on other sites More sharing options...
Eagle Posted November 26, 2014 Share Posted November 26, 2014 I'm getting ready to order my Harland Sharp roller rockers. 2.5 and 4.0 rockers are non-adjustable yet- * Harland Sharp original series, pedestal mount, Jeep 4.0L Inline 6, roller rockers are designed to be a replacement for the factory rocker that fits under the stock valve cover. Simply remove the factory rockers and rocker stands and replace with your new Harland Sharp roller rockers. * These non-adjustable rockers are designed to the factory specs. If you change camshafts or machine the heads, you will have to correct your pushrod length. Always check before installing. * We recommend always checking for head and valve cover clearance and proper lifter preload. Rocker mounts on head have not been machined, cam is one step above stock, push rods are stock. Anything I need to concern myself with here? Thanks Cam one step above stock means the base circle is smaller than the factory OEM can. Depending on how much difference there is in lift, your push rods may or may not be okay and the lifters may or may not provide enough range to compensate. Link to comment Share on other sites More sharing options...
Jeep Driver Posted November 26, 2014 Author Share Posted November 26, 2014 According to Harland Sharp today, phone call.......... I need to get a single adjustable push rod, install with roller rocker, adjust to 0 lash, remove push rod, measure push rod, add .0040 for valve pre-load. Link to comment Share on other sites More sharing options...
