Jacob Ochs Posted November 23, 2014 Share Posted November 23, 2014 I have a 1986 MJ with the 2.8l. I recently switched new gauges It without the idiot lights. I replaced the oil pressure sensor but I couldn't find the 2.8L water temp sensor I any store! So my question is if anyone can link me to a part number for the water temp sensor I need! Any help would be appreciated. Link to comment Share on other sites More sharing options...
Jeep Driver Posted November 23, 2014 Share Posted November 23, 2014 What year is your gauges? Get the sensor for that year and install it. Link to comment Share on other sites More sharing options...
Jacob Ochs Posted November 23, 2014 Author Share Posted November 23, 2014 What year is your gauges? Get the sensor for that year and install it. the year of the gauge cluster is 1990. But the problem is that there is only one wire going to my existing coolant temp sensor and the 1990 is a 2 prong. Link to comment Share on other sites More sharing options...
Jeep Driver Posted November 23, 2014 Share Posted November 23, 2014 The two prong is the ECU sender which does not apply to you. The single wire sender is the gauge sender........you need one for a '90 with GAUGES. Link to comment Share on other sites More sharing options...
Jeep Driver Posted November 23, 2014 Share Posted November 23, 2014 https://www.google.com/search?client=ubuntu&channel=fs&q=Temp+sender+for+1990+jeep+cherokee&ie=utf-8&oe=utf-8#q=Temp+sender+for+1990+jeep+cherokee&channel=fs&tbm=shop&spd=17549016642091334318 Link to comment Share on other sites More sharing options...
Jacob Ochs Posted November 23, 2014 Author Share Posted November 23, 2014 https://www.google.com/search?client=ubuntu&channel=fs&q=Temp+sender+for+1990+jeep+cherokee&ie=utf-8&oe=utf-8#q=Temp+sender+for+1990+jeep+cherokee&channel=fs&tbm=shop&spd=17549016642091334318 okay my existing one doesn't have threads at the top though Link to comment Share on other sites More sharing options...
Jeep Driver Posted November 23, 2014 Share Posted November 23, 2014 You may have to splice in the new plug for the new sender..........whatever it takes to make it work........ Link to comment Share on other sites More sharing options...
Jacob Ochs Posted November 23, 2014 Author Share Posted November 23, 2014 Okay thank you! Link to comment Share on other sites More sharing options...
tugalo Posted November 26, 2014 Share Posted November 26, 2014 Go to a junkyard and find a Cherokee or an early Dakota with the one wire sensor. Link to comment Share on other sites More sharing options...
