dustyinthedirt Posted November 7, 2014 Posted November 7, 2014 i recently bought a 90 Comanche, i will be posting pics soon. i noticed that it burns oil and has a leak on the passenger side above the oil filter under the head only in a four inch or so spot. i beleive it also is leaking around the oil pan as it is pretty oilly and kinda drips from the drain plug. is this gonna be a hard job to do? of course i am gonna take the time and do it correctly. thanks for any advice.
dustyinthedirt Posted November 8, 2014 Author Posted November 8, 2014 it also dosent over heat or any thing that would show signs of the headgasket being busted it just leaks same with the oil pan
Jeep Driver Posted November 8, 2014 Posted November 8, 2014 If it's leaking between the head and block you may assume that the head is warped. If you got to a new gasket........I'd have the head done and the head decked.
