Rough idle, Stalls when driving, horrible gas mileage need help
About 2 weeks about my jeep started to sputter when driving, check the plugs and had one that lost contact. Fixed
This last week the jeep runs rough when first started and sounds like it has a miss, it boggs and sputters when trying to acellerate, and just when i feel its starting to run a little better it will randomly stall while doing 25, 50mph ect . Jeeps deffently running way to rich and i am now getting maybe 3-4mpg. After it stalls it will take a few minutes of cranking to finally start
When running decent it will accelerate, but u can feel it tugging trying to get power
I have a constant 30psi at the fuel rail when running ruff
so far ive changed the following
4 spark plugs ( autolite gapped at 35 )
bosch spark plug wires
tps sensor( adjusted also )
new cps
map sensor
Ive checked all the wires for breaks, and all the hoses are good with no cracks ect
i am now at a standstill and do not know what to check next
motor specs- 1990 block, 1995 xj head, 2000 xj intake manifold ect
any ideas or suggestions would be appreciated
thanks
hey i checked all the grounds in the engine bay, ill have to double check the one behind the tail light. I installed a new o2 sensor when i had my exhaust installed, less then 5k ago.
Small updates-
changed o2 sensor and that fixed the random stall and for the most part mis fire i was having at start up
After i swapped that my idle would not go down under 1500 under any conditions
Bought a new iac sensor ( for an ho since advance did no stock one for my renix )
seems to have fixed the idle, but still surges to around 1200-1500 randomly
still runs to lean from the exhaust smell I'm getting
will update as more progress is made
Have you checked your injectors? I had similar symptoms (bad mpg, misfire,rough idle, slow start, poor accelartion) and traced it to a leaking injector, which also explained the raw fuel smell.
Just saw this post now and decided to check my gauge on the fuel fail. I clicked the key forward ( did not start ) and the pressure was a 32psi. Within a few seconds the psi dropped and after a few minutes was all the way down to 0.   :doh: wish i would have thought of this sooner before buying all these sensors, guess i have some spares for the future.
Really appreciate it, now just have to try and get a replacement and figure which injector is the culprit.
Well there is a "air screw" that you can play with to FINE TUNE the idle only. This shouldnt be used to completely fix the issue here. This sounds like a bad MAP like part of my issue was. I chased a rough/low/varying idle for a long time and finally solved it through everything I changed and checked. Click on my link below in my signature for my story. Lots of good information in there.
Thanks I changed and tested the map, changed and adjusted the tps, the only issue I have now is a high 2200rpm at start up, and it seems to idle are 900-1200. Running rich and still loosing 100miles to a tank, but I, pretty sure the injector is the cause of a few of those issues
The air screw I talked about can settle down that idle. If you click on my link and on one of the last pages there is a good picture of it. Have your truck running and play around with it. Turn the screw in and out and observe the idle changes.
Did you check your manifold bolts?
I would also highly suggest this. If you have a manifold leak then you would smell exhaust (rich smelling) and the vacuum leak would cause a higher idle.
