So, the TPS for the 99 throttle body is different from the 88. So I had to make an adapter that makes the 88 TPS match up to the 99. So I have a blade that attaches to the TPS on the 99 sensor, and "catches" the blade of the 88 sensor. Adjusting that should adjust the idle, right?
Uh, no.
You should adjust the TPS per my instructions in post 8 of my Tips, after making sure the throttle butterfly stop screw is set correctly as in post 14.
I don't have a late model throttle body hanging around so I can see how they're set up or I could be of more help.
What IAC connector are you using and how is it wired?
  On 10/9/2014 at 4:19 PM, Steven Gregory 89 MJ said:
  On 10/7/2014 at 9:36 PM, cruiser54 said:
  On 10/7/2014 at 3:48 PM, Steven Gregory 89 MJ said:
Mine idles anywhere from 250-2200. I have no idea why.
Could be a bad TPS.
Of the Tips in my link below, how many have you done?
I haven't done any.
Do 1,3,4, and 5 to begin with. Could be the cause of your random idle
