relyt120 Posted August 28, 2014 Share Posted August 28, 2014 Check out these awesome battery connectors! Anyone ever use them before? http://www.remybattery.com/Fusion-Solder-Connectors-C1459.aspx Link to comment Share on other sites More sharing options...
ScottJeep Posted August 28, 2014 Share Posted August 28, 2014 My 2 cents....Not to out-right bash your finding of a part source.....In fact I have needed new source for solder pellets so THANKS.... BUT.... I've been going with these Military style connectors for a few years. http://www.oreillyauto.com/site/c/detail/NOC0/TZ620.oap?ck=Search_military_-1_1326&keyword=military Great because you install ONCE. You only remove the one nut to take a cable off. They seem, in my experience to be pretty resistant to corrosion as well. And search O'Reilly and you will see a pretty much exact part from another, from a more name known vendor, for DOUBLE the price. Link to comment Share on other sites More sharing options...
relyt120 Posted August 28, 2014 Author Share Posted August 28, 2014 Those do look nice. What do you do install ring terminals on the battery cables and attach them to the bolt? in that case you could use the connectors I mentioned with these. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 28, 2014 Share Posted August 28, 2014 Brass marine connectors are $5 per pair at OReilly. Copper lugs are $1 each. Solder and heat shrink.........$.50 each No worries........priceless. Image Not Found Link to comment Share on other sites More sharing options...
valis Posted August 29, 2014 Share Posted August 29, 2014 Prefer crimp terminals myself. As long as you have the proper crimping tool for the larger gauge terminal lugs they'll never come undone. Link to comment Share on other sites More sharing options...
