relyt120 Posted August 25, 2014 Share Posted August 25, 2014 Hey guys, been living with/battling this issue for a few weeks so I thought maybe you all had some ideas. So the issue is with my 1989 auto on column Pioneer with the 4.0l 2wd. (sig for link) Whenever I start the truck it starts fine but the accessory circuit does not come on ie no wipers, radio, ac, turn signals. Additionally, occasionally when I turn the truck off the accessory circuit comes on and stays on even with the key removed. At first I thought it was the ignition key cylinder because ever since i have had the truck I could remove the key with the truck running, so I went ahead and swapped that out first thing. I tested it before reassembling the column and reattaching the steering wheel and all seemed well until I got it all back together and the problem persisted. I am thinking that maybe it is the ignition switch but since the truck starts with no problems I am unsure and don't want to make things worse by going down the wrong rabbit hole. I am currently working around the issue by supplying the accessory circuit with power straight from the battery so I can still drive the truck, which is my daily driver. It is working well and I try not to draw too much current so I don't fry the whole thing. Luckily the main things are the tail lights and the wipers so my work around is working pretty well so far, just want to get it back to normal. What do you guys think? :dunno: Your advice is much appreciated. :thumbsup: Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 25, 2014 Share Posted August 25, 2014 A good possibility is ignition switch adjustment or a fried ignition switch connector. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 26, 2014 Share Posted August 26, 2014 The big brown wire on the ignition switch, located down the column from the key switch is fried at the switch. Switch is now bad. Replace switch, clean up that brown connector and wire as needed. Click on my Tech Tips link below and look on pages 1 and 3 to see what I'm referring to. Link to comment Share on other sites More sharing options...
relyt120 Posted August 26, 2014 Author Share Posted August 26, 2014 is this the one cruiser? http://www.cherokeeforum.com/g/picture/1725230 ill check it out this weekend thanks for both your replies Link to comment Share on other sites More sharing options...
cruiser54 Posted August 26, 2014 Share Posted August 26, 2014 Yup. Page 3 has the burned connector photo. Let's take wagers on what the issue is. Is gambling allowed on this site? Link to comment Share on other sites More sharing options...
relyt120 Posted August 26, 2014 Author Share Posted August 26, 2014 Awesome. Here is the link for posterity. http://www.cherokeeforum.com/g/picture/1725291 Will a new switch include a connector or do i need to grab one from the JY? Also I just need to drop the column down to access this guy right? Link to comment Share on other sites More sharing options...
cruiser54 Posted August 26, 2014 Share Posted August 26, 2014 Easiest to lower the column. Connector may not be too far gone. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 26, 2014 Share Posted August 26, 2014 Let's take wagers on what the issue is. Is gambling allowed on this site? No gambling unless it's done back-channel. PM sent. :yes: Link to comment Share on other sites More sharing options...
relyt120 Posted September 8, 2014 Author Share Posted September 8, 2014 you guys were exactly right! The brown wire had melted the connector. Replaced the switch and the plastic part of the connector and the brown wire's terminal. Put it back together and wa-lah! Everything is as it should be =) Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 8, 2014 Share Posted September 8, 2014 Voilà. Link to comment Share on other sites More sharing options...
cruiser54 Posted September 8, 2014 Share Posted September 8, 2014 Not bad for a coupla old farts...... Link to comment Share on other sites More sharing options...
relyt120 Posted September 8, 2014 Author Share Posted September 8, 2014 pics: Link to comment Share on other sites More sharing options...
cruiser54 Posted September 8, 2014 Share Posted September 8, 2014 Thanks for the pics. I've seen that a few times..... Link to comment Share on other sites More sharing options...
