Mr.Oz Posted August 23, 2014 Share Posted August 23, 2014 Doing this tomorrow, so I can't use the valve we got with the booster and MC? see pics Image Not Found Image Not Found Image Not Found the valve has a line for the rear and one for the front going to an abs brake system. Re-plumb this new valve or just remove it and run lines to the MJ valve. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 23, 2014 Share Posted August 23, 2014 Your pics are worthless. Use the MJ distribution block. And trash your prop valve while you are at it, if you have not already. Image Not Found Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted August 23, 2014 Share Posted August 23, 2014 I agree, the pictures you posted are too small to be worth anything.When I did my booster/MC swap, I swapped in an XJ prop valve and got rid of the load sensing rear prop valve. So folks here will say to stay away from the XJ prop valve, but I've had no problem. Take it apart and clean it out really well and you shouldn't have an issue. Link to comment Share on other sites More sharing options...
