Rochester 2SE carburetor
so i found out that i can get all my parts half off through work if i have the parts store order my stuff and charge it through the stores account as long as i pay for it  :banana: so i'm wondering what the CFMs for the rochester 2SE carb is, i read somewhere before that it was around 300, if that's true and i slap a holly carb on it (it's still 2 bbl) that has 500CFM? gotta know before i order a carb i can't use,
Redwolf
Weber makes a 32/36 DEGV carb as a replacement/upgrade for the Rochester one.
Here's the carb size math formula to help you in choosing CFM size. Engine size (in Cubic Inches) x Max RPMs of motor / 3456 = Max CFM.
Now this formula give 100% Volumetric Efficiency and most street motors only run at 70-80% VE
IE: (I'll use a 2.5L as an example) 150 x 5,500 / 3,456 = 238.7 CFM.
So max CFM size would be a 250 CFM.
It's hard to get a carb in the exact CFM size but choose the size closest to the math.
Hope this helps.
500 CFM is too big for a 2.8L.
Using the formula above, for your engine it would be:
170 x 5500 / 3456 = 270.5 CFM
In reality, you probably won't be operating at 5500 RPM anyway, so that 270 CFM for practical purposes will be 245. A 500 CFM carburetor will be twice as much flow as you'll ever need.
Hence the 70-80% VE rating. Only fully built race motors run close to 100% VE.
  On 8/16/2014 at 9:44 AM, redwolf624 said:
  On 8/16/2014 at 3:59 AM, Eagle said:
  On 8/16/2014 at 3:30 AM, redwolf624 said:
but what CFM?
See posts number 2 and 3.
see post number 6, i don't know my max rpms,
Redwolf
Who cares? Redline/Weber has done all the work for you. It works.
5,000 RPM. And you probably will never actually take it that high. If you do, you'll only do it once and after the engine blows up a carburetor will be the least of your worries. Why do you think we used 5,500 and 5,000 RPM in the examples?
You need a 300 CFM carburetor. That Weber kit in Cruiser's link looks like just what you need.
I almost posted that^^ word for word!! LOL.
  On 8/16/2014 at 1:13 PM, cruiser54 said:
  Quote
You probably remember, too. When I bought my '88 XJ new, the service manager at the stealership was a racing buddy, and I hung out in the shop fairly often. Back then there were still a lot of 84, 85 and 86 Cherokees on the road, and every time I went to the dealer's shop there would be another one with a connecting rod blown through the side of the block. You DON'T beat on the 2.8L engine. (And what many people consider to be normal driving, unfortunately, is "beating on it" for the 2.8.)
I remember very well. They would just grenade. Don't know if you've seen this, but in the parts catalog for that POS 2.8 they list shims for the main bearing caps!!
  On 8/16/2014 at 6:02 PM, redwolf624 said:
ok so 300CFMs for a carb for the 2.8, say i could get my hands on a 4.0 but couldn't get the CPU, what CFMs would i need for a carb for a 4.0?
Redwolf
4 liters is 244 cubic inches. Plug that into the formula, use 5,000 as the peak RPM, and do the math. But WHY would you use a carburetor on a 4.0L when the EFI is so much better?
