TheDirtyJeep401 Posted August 13, 2014 Posted August 13, 2014 Having problems trying to find a complete clutch hydraulic hose for an 86 2.5 with an AX-4. I can't find one at parts stores or online. But however they do have a hose for an 87, but isnt an 87 internal slave? Or will the hose still connect? Thanks
yxmj Posted August 13, 2014 Posted August 13, 2014 As long as the ends are the same and it has enough length it will work. :thumbsup: Since you are changing it...take it off and take it with you. To answer your other question my 87 AX5 was internal. To comment.....you do know that clutch lines.....like break lines can be fabricated......the only specialty tool need is one to make the double flare on the end.....some places rent them. . :MJ 1: .
johnr Posted August 14, 2014 Posted August 14, 2014 you may need to get the whole assembly. master cylinder line and slave cylinder.
