the other day i replaced my clutch master cylinder and now the truck will crank all day long but won't start up. the only thing i can think of is it not getting spark because i can smell fuel. I did see a spark fly from the fuse box when i was sliding the push rod into the fire wall. Any Ideas?
Check the CPS, it's likely unplugged.
Did you remove the trans?
If so, and the CPS is plugged in.....you could have damaged the CPS when reinstalling the trans.
