TheDude Posted July 13, 2014 Share Posted July 13, 2014 Hey all, I need a front drive shaft for a Cherokee/Comanche with a manual trans. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted July 14, 2014 Share Posted July 14, 2014 Need to be more specific... 2.5L/AX4/5? 4.0L/BA10 or AX15? There are differences... Link to comment Share on other sites More sharing options...
TheDude Posted July 14, 2014 Author Share Posted July 14, 2014 I was hoping they weren't ALL different.. But of course they are anyway, mine is 4.0L AX 15 Link to comment Share on other sites More sharing options...
TheDude Posted July 23, 2014 Author Share Posted July 23, 2014 Bump Link to comment Share on other sites More sharing options...
88ComancheMitch Posted July 27, 2014 Share Posted July 27, 2014 How can you tell if it's an ax 15 vs. Other manuals? Link to comment Share on other sites More sharing options...
TheDude Posted July 27, 2014 Author Share Posted July 27, 2014 They went from the BA 10 to the AX 15 mid year 89. I'm not sure if they are different lengths or not. I measured and it's 32" yolk to yolk on the truck. So the driveshaft has to be a bit shorter than that fully compressed. If I remember, I'll measure the original shaft and post that info. Link to comment Share on other sites More sharing options...
88ComancheMitch Posted July 28, 2014 Share Posted July 28, 2014 There is a 87 at the junk yard. I was going to grab it. Sounds like it will be wrong style tough. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted July 28, 2014 Share Posted July 28, 2014 Just be aware that a front DS from an AW4 equipped MJ/XJ will not work on a manual trans. equipped MJ/XJ. The AW4 version is an inch longer than the AX15 and BA10 versions. Link to comment Share on other sites More sharing options...
88ComancheMitch Posted July 28, 2014 Share Posted July 28, 2014 Just be aware that a front DS from an AW4 equipped MJ/XJ will not work on a manual trans. equipped MJ/XJ. The AW4 version is an inch longer than the AX15 and BA10 versions. So all 5 speed tcase driveshafts are the same? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted July 28, 2014 Share Posted July 28, 2014 IIRC, the BA10, AX15 and NV3550 that are found behind 4.0L are of the same length. But the 4-banger Jeeps are different than the L6 Jeeps. Link to comment Share on other sites More sharing options...
TheDude Posted July 28, 2014 Author Share Posted July 28, 2014 Yeah, I tried to borrow one from an auto already and it was too long. Link to comment Share on other sites More sharing options...
Timeless Posted July 28, 2014 Share Posted July 28, 2014 I have one that is 30.75" compressed/34" extended and one that is 29" compressed/32" extended (measured with u-joints straight on a flat surface). Both are from running/driving rigs, but have been sitting around in my garage for a year or two. Shipping to you for either would run about $20. If you're interested, send me a PM. Link to comment Share on other sites More sharing options...
Thexjfiles Posted July 31, 2014 Share Posted July 31, 2014 AX15 have an aluminum section near the rear, and the AX10s have a cast piece. I just pulled a front shaft from a 96 XJ that has a D30, and an AX15. Shaft is $55 plus shipping from NC. Link to comment Share on other sites More sharing options...
bumpy Posted July 31, 2014 Share Posted July 31, 2014 i think i have one, whats the length you need? mine was a 4.0/ax15/231/d44 Link to comment Share on other sites More sharing options...
TheDude Posted July 31, 2014 Author Share Posted July 31, 2014 Mine is the same as yours, aside from your higher quality rear axle.. I got 31" - 33" compressed/extended lengths when I measured, but those may be slightly off. Link to comment Share on other sites More sharing options...
bumpy Posted July 31, 2014 Share Posted July 31, 2014 PM'd you Link to comment Share on other sites More sharing options...
