Instrument Cluster With Gauges Not The Idiot Lights
Got an 88 and looking for the older color scheme instrument color (darkish blue)  not the black and red.  I'm not sure which would be compatible,  Mine right now has the big fuel gauge and the speedo gauge with idiot lights.  I have column shift, so I have the indicator.  I know if i get a cluster with gauges i would have to get new temperature sensor and oil pressure sensor.  Not sure what will happen if its one with a tachometer since I don't have one.  I'm guessing ill have to get the 3/4 cluster which has the big fuel gauge still and no tach.
If you install a cluster with a tachometer, it will work. The wiring is in the harness and the signal is being sent. All you need is the tach. Your problem will be finding a cluster with the indicator for the automatic trans. Someone posted a fix with an indicator mounted on the column, not sure who it was.
Just saw a photo of Hornbrod's truck with the column mounted transmission indicator. Look at the post for shifter knobs in the Pub section.
Okay thanks guys. Would love to have a tach and that's good to hear that it'll work! Now to find a cluster! Haha
Probably Renix era trucks 87-90 as they use mechanical speedometer drives. The speedometer end of the cables may differ in the way they connect/clip onto the speedo hub during those years. The ideal find would be one like Dainternetguy's in the color scheme you want. I believe someone on the forums has grafted the shift indicator into a non-auto cluster and someone else has mounted a shift indicator on the column. Both mods should be/may be in the DIY section.
Like so (not my truck)
Nice tack modification.  Where did you get the picture from?  This is on my "to do" list of half way finished projects somewhere/sometime.
