Can I put a automatic transmission out of a 2.5L 1986 Cherokee into my 2.5L 1989 Comanche.  The Comanche is a 2wd and the Cherokee is a 4wd. Looking to convert the Comanche to 4wd.  Will there be wiring issues.  If it is feasible I will be buying the entire Cherokee, but will the two electrical systems match up.
It would probably swap but its gonna be a 3spd 904 trans, personally I wouldnt wish a 2.5l/auto combo on anyone.
Agreed.
Any balls your 2.5 has..........will simply roll away.
Some 2.5l autos came stock with 4.56 gears, the stock axles can only go 4.88 so much bigger then a stock size tire and you won't be able to achieve proper gearing without an axle swap.
MJ Junkie... best laugh I have had all day.  I am having a rough time finding an AX5 out of Cherokee to put in my Comanche.  I would really like to get this thing on the road.  I have a set of 4.10 axles out of a Cherokee to complete the 4wd drive conversion. I just can't find a trans.  I found a 2.5L automatic Cherokee today and was tempted to buy it so I can get mine on the road. Well that being said I guess I will keep looking for the AX5. Thanks for the input.
Shouldnt be that hard to find an AX4 or AX5. Even one from a wrangler will work,you would just need to drill it for MJ/XJ clocking unless you want the Wrangler clocking.
Too bad your not close by, I have a couple of them sitting around.
