Roost426 Posted June 23, 2014 Posted June 23, 2014 Hey all, had a battle with my waterpump today and finally got it all mostly back together. Just a quick question on the long tensioner bolt on the side of the power steering pump. What does the long tensioner bolt ( D in image) actually thread into? is there a nut thats supposed to be in there somewhere. or is the bolt just clamped onto by tightening C? Just having a hard time seeing how it works guess I should have payed closer attention when disassembling.
nitroxsteve Posted June 23, 2014 Posted June 23, 2014 "C" has a square block on the back side of the bracket thar "D" threads into.
Jeep Driver Posted June 23, 2014 Posted June 23, 2014 If you completely removed or unthreaded C and D.........the block fell off and you will need to find it.
Roost426 Posted June 23, 2014 Author Posted June 23, 2014 Yep that little fella is MIA, gonna need to find a donor I suppose. Thanks everyone!
HOrnbrod Posted June 23, 2014 Posted June 23, 2014 Most are MIA or stripped out at the yard. If you can't find one get it here: http://stores.zmjeeps.com/collar-adjusting/ Part number 53002915
