crogahn Posted June 23, 2014 Posted June 23, 2014 It's breaking my heart, but I'm looking for a new home for my 1988 Comanche Pioneer Shortbed Pickup. It's been in my family since it was born : ) The Details: 164,812 miles (Almost no winter driving, no offroad) Clean Title Automatic 4.0L 2WD Starts, Drives, Has been run on Mobil1 Synthetic Solid Frame Doors, Rockers, Corners Solid Tan Interior, Bench Seat Sliding Rear Window Plastic Bedliner New Brake Master Cylinder, New Hard Brakelines, New Rear Wheel Cylinders, Newer Heavy Duty Front Rotors and Calipers, Front Wheel Bearings Replaced Brakes need bleeding Harmonic Balancer, Bosch Water Pump, Shocks, Motor Mounts, Starter, Valve Cover Gasket, O-ring under OIl Filter have been replaced in the last few years Stock Clutch Cooling Fan has been upgraded to the Heavy Duty Truck was going to be a project, so the Interior has been dissassembled (have all the parts). On the exterior, rubber molding (have most) and original vinyl graphics have been removed. Sanding of the paint had started, so some of the body is in primer. Some minimal light surface rust in those areas. One dented area on the right rear bed edge where my brilliant brother dropped an oak branch. Good Michelin Tires and Stock Aluminum Wheels Have a few boxes of new parts (about $600) that will be included with the truck: Door Lock Cylinders (NIB) Custom Aluminum Expansion Tank (NIB) was 162.48 with shipping New Set of Door Rubber Seals Assorted Sensors : Bosch O2 AC Delco Idle Air Control Valve Standard Engine Coolant Temperature Sender Standard Coolant Temperature Sensor Heater Valve 4 Seasons Side Markers (NIB) Metal and Silicone Head Gasket - hasn't needed it yet Large Piece of Tan Headliner Fabric (From Team Cherokee I think) 2 Bumper Guards 2 NAPA 4G Battery Cables There may be more parts, books & manuals up in my garage attic, I will include everything I can find. There are also a few bins with used parts from junkyard trips. The only things I know are missing are the spare tire and the headliner board. So that's it. I'm looking for $1400 which includes all the new parts. I am located in Revere Pa which is about an hour or so northwest of Philadelphia and 20 minutes south of Easton.
Archived
