Wj Control Arm Swap
I need some input from those who have swapped the WJ UCA and LCA into their MJ...specifically - was there a particular year (of WJ control arms)  that you chose to use? I know the 99 through 04 arms are the same, but want to make sure.
Thanks
I got the generic 99-04 Wj CA's from ebay, Think it was like $100 for all four new?
The bottoms go on with a slight cut of the metal bushing & The tops require a little more work IIRC, My tops went in fine because i had a drop bracket
