onlyinajeep726 Posted May 12, 2014 Posted May 12, 2014 Does anybody know where I can find just the O-rings for the hydraulic lines that run to the power steering box? I have a slight leak coming from the return line fitting. I replaced the high-pressure line a few months back (which came with a new O-ring for it). Now I just need one for the low-pressure side.
Keyav8r Posted May 14, 2014 Posted May 14, 2014 Or take it to NAPA if you have them in NC. They usually have a good selection of o-rings.
ParadiseMJ Posted May 15, 2014 Posted May 15, 2014 You might want to specify Viton or Nitrile (for "substances") o-rings as opposed to just regular old rubber (used for water etc.).
onlyinajeep726 Posted May 15, 2014 Author Posted May 15, 2014 You might want to specify Viton or Nitrile (for "substances") o-rings as opposed to just regular old rubber (used for water etc.). Good tip, sir. I was actually wondering what material it should be made of. I'm running Royal Purple Max EZ fluid and I don't want to leak that stuff. Too expensive to waste.
