1989 Eliminator Posted May 9, 2014 Share Posted May 9, 2014 Sometimes when i start my truck it starts fine. Other times its very rough and idles around 500 or less. Like it wants to stale. One time it actually did stale just from idling. So i replaced the o2 sensor and tps because i thought those were tthe culprits. And i have 89,000 miles so a new o2 wouldnt hurt. My cps was brand new from mopar two years ago. What else could this be? My exhaust smells very rich. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted May 10, 2014 Share Posted May 10, 2014 Check the vac hose from the TB to the MAP sensor. They like to crack with age causing a bad vacuum with to the sensor. The MAP directly controls A/F ratio. Link to comment Share on other sites More sharing options...
1989 Eliminator Posted May 10, 2014 Author Share Posted May 10, 2014 I replaced all the vac lines. Including the map to tb one. I went through cruiser54's tips and did all i could for those too. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 10, 2014 Share Posted May 10, 2014 I'm suspicious of that tube also. Unplug it at idle when it's acting up and see if things get worse or stay the same. Also be sure the electrical plug is secure in the MAP. Link to comment Share on other sites More sharing options...
1989 Eliminator Posted May 10, 2014 Author Share Posted May 10, 2014 So today i started it and the rpms were weak and after a little bit of idling it staled Link to comment Share on other sites More sharing options...
1989 Eliminator Posted May 10, 2014 Author Share Posted May 10, 2014 I checked the map sensor readings: ignition on, engine off: 4.7 V Hot engine idiling: 1.66-1.85 V Good ground Tps readings: Resistance from tps to firewall: .11 ohms 17% voltage difference Link to comment Share on other sites More sharing options...
1989 Eliminator Posted May 10, 2014 Author Share Posted May 10, 2014 Scratch that .11 ohm reading. Its 5 ohms. I had it on the wrong setting Link to comment Share on other sites More sharing options...
cruiser54 Posted May 10, 2014 Share Posted May 10, 2014 5 is kinda high. Whaddya mean .17 "difference"? Link to comment Share on other sites More sharing options...
1989 Eliminator Posted May 10, 2014 Author Share Posted May 10, 2014 Eh i had the ignition on when doing the ohm test. I did the ohm test with ignition off and it was nearly zero. And my tps voltage on the C terminal was .8 and the input voltage was 4.7 volts. So, 17% difference. My map and tps seem fine. I did some tests on egr and when i unplugged the electrical connection with the output hose off (hose from solenoid to transducer) there was vaccum. Which is good. But when i put the output hose on there was no difference in idle. The hose is new. So I'm thinking its the egr valve not operating correctly. Link to comment Share on other sites More sharing options...
