Truckcom Posted May 9, 2014 Share Posted May 9, 2014 Thought I would get my 89 4L parts Comanche going after a long sitting spell. After a new fuel pump it will only start [with luck] after releasing the key from start to run mode. What is supposed to provide spark while cranking? I assume there is relay of some sort which is not doing its part. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 9, 2014 Share Posted May 9, 2014 You could have a bad ignition switch. Link to comment Share on other sites More sharing options...
Eagle Posted May 10, 2014 Share Posted May 10, 2014 Have you actually tested for spark while cranking, or are you guessing that there's no spark based on when the engine decides to start? Link to comment Share on other sites More sharing options...
Truckcom Posted May 10, 2014 Author Share Posted May 10, 2014 Yes I have. I was checking spark at the coil and noticed no spark while cranking but after releasing the key to the run position there was a spark or two just before the engine stopped turning. Then I realized I could start the thing if got my on off timing just right. Isn't there some system that is supposed to provide higher voltage to the coil when in starting mode? Link to comment Share on other sites More sharing options...
cruiser54 Posted May 10, 2014 Share Posted May 10, 2014 Yes I have. I was checking spark at the coil and noticed no spark while cranking but after releasing the key to the run position there was a spark or two just before the engine stopped turning. Then I realized I could start the thing if got my on off timing just right. Isn't there some system that is supposed to provide higher voltage to the coil when in starting mode? There's a system that gives higher voltage to the fuel pump is Start position. You have the classic bad ignition switch problem. Link to comment Share on other sites More sharing options...
