I'm seeing a significant voltage drop on the gauge when any accessory or light is on.  I can watch the gauge tick up and down with the turn signal and I see a massive drop when the vent fan or headlights are on.
I'm thinking I need to rework the battery cables.  I've seen a write-up or a link to one on here before but can't seem to find it now.
Does anyone have input on the best way to upgrade this?
The link you're looking for is below: Start with Post 1. Less than $15 in parts and takes about 45 minutes to do.
Post 3 is good to do also. What year?
Thanks.  I'm probably going to get the kit from Kelleyswip
Cruiser can you give me more info on the reasons for doing #23? Seems easy enough but what problem does it solve/prevent?
Little bit more power.
